- Jun 24, 2021
- 7,510
- Vinyl
- CircuPool RJ-60
I have received my test kit.
FC- 29.5
TC- 2
CYA- 90
FC- 29.5
TC- 2
CYA- 90
To get to recommended CYA level 60. About what percentage do I need to drain the pool?Good deal. A couple comments/questions:
Other than that, just follow the instructions on the SLAM Process page and you're good to go.
- The FC/CYA chart calls for a FC level of 35 ppm when slamming with CYA of 90. It will drop quickly on you as algae consumes chlorine, so it's normal to test and see that it's under, but when you add chlorine, you're shooting for 35.
- The FC/CYA chart also recommends dropping CYA by draining or exchanging some water when your CYA level is 90. But if you're OK maintaining 35, then you don't have to drain.
- Do you mean CC (combined chlorine) instead of TC (total chlorine) ? TC cannot be less than FC, by definition.
It's safe to swim in the pool up to full SLAM level, so yes.Also is the pool safe with the current chlorine level?
Just remember, moving forward until the CYA comes down you need to keep that FC between 10-12.Great thanks. You all have provided the best information and assistance. I want to make sure this never happens again. I will work on getting the CYA to 50. Afterwards, I will have some maintenance questions. Maybe post a new thread.
Will doJust remember, moving forward until the CYA comes down you need to keep that FC between 10-12.
