Struggling with New Layout
Mutchinator
0
46
Lehigh Valley, PA
Pentair Intellichlor IC-60
Hi - I’ve been trying to find a reasonable layout based on new equipment and location of plumbing and connections.
Seeking advice on best layout for equipment as plumbing challenges exist depending on where I locate.
pics attached -
1) two way valves horizontal on each suction and returns line
2) three way bypass around heater as well as checking valve on output of heater
3) Pentair SWG (not shown)
4) All Pentair aside from Raypak 406
5) open to changing location or orientation of any pieces of equipment
6) Are there any limits or recommendations with respect to distance between pump/filter/heater etc?
7) Normally I see filter on right, pump in middle then heater on left - but does this matter?
8) I can extend the 3x8 concrete pad if needed
9) Pentair Intellicenter
10) Debating on using MPV or just three-way for waste/filter.
Advice greatly appreciated...
So it may be as simple as I was hoping :) - I will be running the 2-way suction valves parallel to the pad and then Tee-Y followed by checkvalve into pump. Will have around 18" to work with. Yes def going to be getting creative with plumbing but good to know the distances are not going to be an issue. Much appreciaed.
