You should be seeing none.
Ugh, this must be frustrating. But it feels like you're close.
Algae will not spontaneously bloom in water with 40ppm CYA and 5-7ppm FC, so I can only think of a few things that might be happening:
- FC is lower, at least in some places and/or at some times, than 4ppm.
If the algae is consistently appearing in the same places, try performing FC tests with water from those areas/depths, at worst-case times of day: early afternoon, 11 hours and 55 minutes after the pump turns off, etc.
Good idea, I have not tried this. It's first visible on shallow end and deep end only.
- CYA is much much higher than 40ppm.
If this were the only cause for the algae bloom, it would have to be WAY higher -- like 100+. Very unlikely.
I checked this with tf pro kit I have and two pool stores. I get 40, pool stores say 40 and 43.
- An active algae colony was introduced after the SLAM.
Your earlier posts indicated that the cover was a likely source of algae. You said you maintained the SLAM FC level with the cover on -- so floating, not weighted and submerged, right? Have you used the cover since completing the SLAM?
No cover for months.
- The SLAM did not kill all the algae.
You earlier discovered some algae in a disused tab chlorinator. Is it possible that algae is hidden in other parts of your plumbing? Maybe in other unused portions (e.g. an old booster pump that's been replaced by a robot), in the fill hose or autofill/overflow pipes, under drain covers, behind weir doors, inside light niches, etc. This was before finishing SLAM. I overdid the SLAM by days. Perfectly clear water and not a trace of algae anywhere. Pipes would all have had shock levels through them, pool is brand new. I backwashed the filter twice, right after the SLAM was done and two days later again.
