Hi All,
We have a 2 month old pool and we've been struggling to get the Total Alkalinity under control, and I was hoping for some advice.
We filled our pool and right from the start the TA was off the charts high (using both cheap test strips we had, and a Taylor K-2006). The PH was around 7.8 so a bit high. So we plugged everything in to the pool math calculator and have been adding muriatic acid as recommended. We have now adding something like 15 gallons of it, but the TA is still super high - and we then ended up with a PH of 6.8. So we added Borax as recommended and PH is now good.
So just not sure what to do now? I add muriatic acid to try and get TA under control, but then have a ph problem . . .
Darryl
Darryl
