Hi! First time poster. Last spring/summer we were caring for a terminally ill dog in a wheelchair and did not end up opening our pool at all, so it was closed for 2 years. The winter cover shredded in places, and we opened the pool a month ago to a brown, smelly swamp. Went through 30 bottles of shock, various recommendations from different local pool stores (non-copper algaecides, clarifiers (not floc), phosphate remover). Two different pool store chains' employees told me very insistently that CYA does not matter and I should not add it because it's hard to remove. Probably why I went through so much shock? I had 0 CYA when I opened.
I got a K-2006 Taylor kit. I THINK my CYA is now 41 or 42 after slowly adding stabilizer and testing following instructions on here (waist-high, back to the sun, and at-first-glace with the dot). The PH was at 7.3 or 7.4 when I started SLAM a few days ago. We put in a new cartridge filter. I add the amount of shock - sometimes liquid, sometimes Cal-Hypo - that PoolMath says for SLAM at 41 CYA, and test twice a day, but every time I test it's still never at SLAM level. Stays around 0.5 CC and 7.5-12.5 FC. I keep a floater w/2 Tri-Chor tabs in too just because I'm apparently losing so much FC between shocks and I don't think my CYA is too high yet. All the leaf debris seems to be out now and I brush every couple of days.
(1) Pool temp is 73. Would adding a solar cover to raise the temp help the process? I seem to remember one season the cloudy water wouldn't clear until the pool temp went up higher than that, and I had a different pool app (sureTREAT) that claims water should be at least 78 for chemicals to work properly.
(2) We have a 12 mill solar cover that is still intact and hosed off but still pretty dirty from not being stored well. We're thinking of replacing it anyhow with a new one, so degradation from high chlorine's not a big deal. But would dirt and algae on it just make the situation worse?
(3) Our pool's vinyl liner has brownish staining. I assumed it was tannins from a nearby oak tree's leaves, but when I held a Tri-Chlor tab on it for over a minute, I saw no difference. Pool store water test said I have 0-0.3 Total Iron and Copper. Should I try a Vitamin C tablet anyways and see what happens?
Sorry such a long post. I kind of feel like giving up. I know I only started the SLAM a few days ago, and I guess it's been getting slightly better each day since then, but very slightly. And after a month of working on this I'm so discouraged. I can now see the brush at the bottom in a blur, but it's still quite cloudy.
