I have an above ground pool that has a main drain and skimmer with sand filter set up. I was replacing the handle on my Waterway TruSea 3-way diverter valve. I took the cover off (not sure why) and when reinstalling the cover I may have stripped some of the screw holes. I think I did because the screws now can be put in screw holes easily and spin some - they do screw in but at first you can push the screw in the hole by hand. The other screw holes are tight. I did see some of the plastic in a spiral shape come out of the diverter screw holes.
Is this fixable or will I need to replace the entire diverter?
