I have four actuator valves and four Pentair check valves in my system.
I recently disassembled them for the first time since buying house. I think they are 12 or so years old.
I found that every actuator had at least one stripped screw and same with check valves.
One check valve, the screw hole thing is broken off.
I don’t think anything is leaking yet, but I don’t want to come home to a blown valve and empty pool.
I saw some useful posts about epoxy filling the stripped ones.
Anyone with any thoughts on the broken one?
My only good idea so far is to build up an area (bigger than the original hole) with JB Weld and drill a new hole?
I fear even epoxy won’t stick well to the black plastic (anything better out there?)
TIA, Rick
TIA, Rick
