I have a salt pool installed just under 3 years ago. Everything is working normally as far as I can tell, however in the past couple of days I have noticed that when I clean the strainer basket (right before the Pentair VS pump), the water isn’t gurgling upon release of pressure that normally occurs when I unscrew the lid. It recedes slightly but doesn’t gurgle back thru the system (sometimes I would even add water to prime the pump when restarting since the level drops significantly) as it did normally and I’m wondering why?
