We had a pretty bad storm last night. Check the pool this morning, pump is off. Check the breaker box & it's tripped & panel says Check System Reset. The actual system is working, the breaker for the lights is on, but the pump breaker is off. There is a GFCI reset button, but it won't push in. We've turned the breaker to the off position, tried pushing the reset button, still won't flip back to the on position (goes to middle). We took off the cover & checked fuses, but they all look fine. Checked the MAIN breaker box & the pool is in the on position there. Flipped that one on/off, but still no change at the breaker by the pump.
Not sure if it's a bad breaker (& if that's something we can fix ourselves) or what else???? Help!
We have Hayward MaxFlow VS pump, Hayward Goldline Prologic Control System.
