- Jul 21, 2013
- 65,062
- Plaster
- Pentair Intellichlor IC-60
TLDR - My IntelliCenter OCP was bricked by a storm and to get a parts I am considering buying a full new IntelliCenter bundle, keeping some parts, and selling the rest.
I have been traveling the last few weeks. The IntelliCenter was left on its normal schedule running the VSF pump 24/7 and pool cleaner daily, with the Intellichlor % slightly high. My housekeeper checks the house every few days while I am gone and cleans the skimmers as needed. I also put a gallon of liquid chlorine in the pool to raise the FC an extra 3PPM just in case.
A big thunderstorm rolled through the area and I got a call from my alarm monitoring service that the house alarm went off. That was the first sign something was amiss. I reset the alarm, checked the house cameras, and told them to ignore the alarm. The front door sensor had set off the alarm. I saw on the cameras the rain and wind blowing around the house.
I tried to get into the IntelliCenter2 app to check on the pool but it told me the pool was offline. I got an early model IntelliCenter that came with the Engenius WiFi link which is flaky. If it loses WiFi connection it does not always reconnect without a power cycle. I figured maybe the power in the house had burped.
The next day my housekeeper texts me that nothing is running on the pool and the IntelliCenter OCP display is blank. Touching the panel does not get it to light up. Interesting though is that I have an Indoor Control panel (ICP) and that still works but shows only a pool, not a Pool and Spa. Further the Intelliflo VSF control panel is lit and the pump can be run from its controls. He tried powering down everything at the breakers with no change to the dead OCP.
So I had him turn on the pump at 2400 RPM that restored pool circulation. I had two cases of liquid chlorine left from the pool opening and had him put two gallons into the pool and a splash into the spa. That was his routine when checking the house until I returned. I told him where to pickup a few more cases of liquid chlorine. That kept the pool circulating and chlorinated.
The Intellichlor cell was dark since it was powered from the filter/pump relay which was open while the IntelliFlo pump had constant power from the LINE side.
So when I returned I confirmed the IntelliCenter was dead. However the PCB had 24V AC since the ICP was powered and the Engenus WiFi had its LED lights on. So there was power to the PCB board but it looks bricked.
I should also mention that the storm killed a Chamberlin WiFi garage door opener that I installed in March and I found the GFCI CB tripped for some of my outdoor landscaping lights. So what ever hit around the house set off the alarm and took out electronics in one area with the pool equipment on the other side of the garage wall. I do have a Siemens FirstSurge protector in my IntelliCenter panel and its status lights still glow green. So whatever hit was external to the high voltage feed.
First thing I wanted to do was get the IntelliChlor running. I took the wires off the filter/pump relay and used tow 3 wire Wago connectors to connect the pump CB, Intelliflo, and IntelliChlor power to run 24/7. I love those Wago connectors and keep various ones to splice wires. I also used a Wago to splice together the firemans switch to the MasterTemp heater to give me local control of it. The other thing i did was pull the actuator off the return diverter, put the handle on the diverter, and crack the spa return open to get constant spillover and keep the spa chlorinated with the pool. Now I had the basics running old school non-automation.
Now to the dead PCB. I looked closely and cannot see any burned components. I labeled each wire and disconnected all the wires to it and removed the board. @ogdento @JamesW @Jimrahbe here are both sides of PCB to see if you see anything I don't.
The board is 3 layers with two boards stacked and the display screen on plastic standoffs. I tried to remove the four screws holding the two boards together and they did not simply separate as I expected. So I have not got a good look at the other sides of either board. I don't think it really matters as I think the PCB is bricked with the storm frying the CPU or memory.
I went shopping online for a PENTAIR INTELLICENTER REPLACEMENT BOARD 523050 and to looks like they are hard to source. Polytec Pools has them on backorder. I also don't know if my i8PS Personality card P/N 521968Z is good or not.
The main PCB costs about $800 and the i8PS card another $800. PolyTec Pools has a full i8PS bundle with IC60 for $4,000. The IC60 is worth $1,600 and the two Intellivalves are another $500. The bundle lets me replace the Engenius Wifi with the more reliable 900MHZ link which costs about $500. And now I have a cabinet, 8 relays, temperature sensors, spare surge board, and other miscellaneous parts for free. What I don't need I can sell and come out ahead.
Unless anyone has other ideas for getting my IntelliCenter going quickly I think the quickest path is getting a new bundle from Polytec, using it as a parts doner, keeping some spare parts, and selling the rest.
Tom, @ogdento , would you like my bricked IntelliCenter PCB to autopsy? Maybe we can learn something about why it failed. I seem to not be the only one where a storm bricked their IntelliCenter. In 20 years my Aqualink never blew out.
Now onto my Chamblerin garage door opener that I bought from Home Depot in March and Chamberlain is saying the PCB is obsolete and not available for $120 so I have to get a new unit for $190. This is fodder for a different thread.
