- Aug 22, 2019
- 10
- Fiberglass
- Jandy Aquapure 1400
Hi All,
I am a relatively new pool owner and have used TFP exclusively for all my pool chemistry education. We have a saltwater, fiberglass pool with an autocover which stays closed 99% of the time. This spring is only my second time to open our pool. Last year, we opened to a perfectly clear pool with a little bit of FC remaining from the offseason. This year I opened to a slimy and cloudy (not green) pool with the following readings:
FC=0.0
CC=0.0
CH=150
TA=100
pH=6.8
CYA=0
So remembering all the advice on this forum, I started the SLAM by dumping in liquid chlorine (between 7.5% and 10%) that I got from various sources. To my surprise, the FC was dropping back to near-zero immediately with the CC going through the roof. After dumping in 17 gallons and still having near-zero FC, I did some more research on TFP to conclude that I was probably dealing with Amonia. The fact that my CYA opened up to 0 was a very telling clue that I'll remember in the future.
So after 2 days of dumping in lots of liquid chlorine, 4lbs of Borax for pH, and 4.5 lbs of Stabilizer, I ended up with the following readings:
FC=15.0
CC=1.5
CH=150
TA=120
pH=7.2
CYA=30
The water is noticeably cloudy, although much better than when we opened. Now here is my problem. I have maintained this FC count for 12 days (plus 2 days of initial Amonia removal) and nothing is budging. I will lose a little bit (1-2ppm) overnight so I turned the SWG on to 10%, keeping FC between 15-17 at all times. The CC stays between 1.0-1.5 and the cloudiness isn't getting better. Without any noticeable improvements over the last 10 days, I'm wondering if this is working. I know you are all going to tell me to be patient and wait it out but am I really going to wake up to a crystal clear pool one morning? I feel a little bit insane for doing the same thing every day and expecting something to change.
Thanks in advance,
George
FC=0.0
CC=0.0
CH=150
TA=100
pH=6.8
CYA=0
FC=15.0
CC=1.5
CH=150
TA=120
pH=7.2
CYA=30
Thanks in advance,
George
