Still Losing Chlorine
Gary_PA
20
Furlong, PA
Hey guys I am new to the forums,
After being pool stored for two years and spending close to a thousand dollars per year battling bi-weekly algae outbreaks I found this great site. I started using the BBB method a few weeks ago. All my numbers look good now accept for TA which I am working on. The water is crystal clear and CC is less than .5 usually around .2.
My issue is that I am still using about 1-2 gallons of 8.3% chlorine per day and I cannot pass the OCLT. I am losing 2-3ppm overnight. I started a SLAM on Sunday night and my test results for the following 2.5 days are below. Based on a CYA of 40 my target Shock level is 16. I have maintained that as best I could and last night even pushed it to 22 to see if that would help. This morning I was down 2.5ppm again. Any ideas? Do I just need to run longer? Should I be looking at something else?
6/3/2017
6/4/2017
Pool Store
My Tests
FC
2.5
4.4
TC
2.9
CC
0.2
PH
7.8
7.6
TA
160
AdjA
101
CH
436
350
CYA
65
40
TDS
900
TIME
FC
Added
6/4/2017
5pm
19
9pm
14
1Gal 8.3%
11pm
18
6/5/2017
6am
15
1Gal 8.3%
8am
15
1Gal 8.3%
10am
18
12pm
17
2pm
18.5
4pm
16.5
1Gal 8.3%
6pm
21.5
8pm
17.5
1Gal 8.3%
10pm
19
2Gal 8.3%
6/6/2017
10am
15
1Gal 10%
12PM
16.5
1Gal 10%
2pm
20.5
4pm
18.5
6pm
17
2gal 10%
10pm
22
6/7/2017
6am
19.5
Gary
A SLAM can take a while. To verify a few things:
Make sure your pump is running 24/7 to move water.
Make sure to be completely brushing pool at least once/day. Scrub carefully around space, lights, ladders, ...
Clean filter as needed.
Take morning reading before direct sunlight hits pool (will burn off chlorine) - 6am seems plenty early.
Thanks for the reply Gary,
I always run my pump 24/7. I know it is overkill but at least for now better safe than sorry. I have been brushing twice a day and have a Polaris 9550 robot running 3-4 times a day as well. I changed filter media just before SLAM and pressure has not moved yet so that should be good. Like I said it is crystal clear so I do not see filter being an issue.
Also wondering at what FC level are their diminishing returns? Do I jack FC up to 30? Will that make things go faster? Should I stick with the pool math recommendation of 16?
Thanks again,
Gary
drharris,
I do not have an autofill but I did just replace about 75% of my water last week in order to get CYA down. I was over 120 and now I am at 40. It has rained lightly the last couple days as well. Not to mention Worm-A-Palooza. Just vacuumed a couple hundred worms out this morning.
Gary
Apart from looking behind the light niche which is a classic algae hiding spot I think Pool Owner Patience (POP) is required here.
Generally a SLAM is going to take a minimum of 4 or 5 days in my experience. This would be for a relatively clear pool perhaps with some cloudiness and a high chlorine demand.
Ah, ok. Unless it rained more than an inch while doing OCLT, that alone wouldn't explain it. By water replacement I meant like if you had a leak that was being topped off by an autofill, it could be FC loss from the leak. You might also try to help circulation by pointing returns downward.
I agree with Jezza that other than seeking out niches for algae growth like light, stairs, etc., it may just take a bit more time due to whatever was growing. It's frustrating when it's so clear (good main drain detail in that pic), but there's clearly something in there eating away at FC.
Thanks Jezza,
I am not so good at POP. Good to know that 4-5 days is the norm. I was just watching the dollars fly out of my wallet again and not sure it was worth it. I will stay on course and keep to the recommended 16 ppm shock level for another few days. I will also remove the lights and check behind them. I think I know the answer but should I use an algicide to brush behind the lights or is brushing alone enough?
Gary
Quick Update
Beginning day 4 of SLAM. I jacked up the FC to 25ppm again last night at 10pm and this morning at 6am it was down to 21ppm so I am still losing too much chlorine overnight. I will stay the course.
I have checked the lights and they had a good solid seal. I took them apart anyway and brushed real good. i did not see anything but did it anyway. My Polaris is a robot so it has no hose and I bleached the waste basket (cleaning bag) just to be safe.
It looks like it just may be a matter of time. I will keep it going but have a question. It is supposed to get nice this weekend and the pool may finally be warm enough to swim. Is it safe to use the pool during SLAM with FC at 16-20?
SUCCESS!!!!!,
You guys are amazing. I was really starting to lose faith but after 9 days and 31 gallons of bleach it worked. I have included a chart of what my results looked like for others to get a better sense of what a SLAM looks like. I am losing less than .5ppm overnight now with .0CC. The only down side is that it looks like it will take about a gallon per day of chlorine to keep my levels up. I am losing about 3ppm per day to the sun. My new solar cover just came in so maybe that will help a little.
Thanks again for all the help. This is the best forum I have ever participated in. Everyone is knowledgeable and HWA (Helpful Without Attitude).
Date
TIME
FC
Added
Date
TIME
FC
Added
6/4/2017
6/10/2017
6am
20
5pm
19
10am
18
9pm
14
1Gal 8.3%
2pm
13.5
1Gal 8.3%
11pm
18
6pm
16
1Gal 8.3%
6/5/2017
6am
15
1Gal 8.3%
10pm
19
8am
15
1Gal 8.3%
6/11/2017
6am
17.5
2Gal 8.3%
1.5 OCLT
10am
18
2pm
15.5
1Gal 8.3%
12pm
17
10pm
14.5
2pm
18.5
6/12/2017
6am
13
2Gal 8.3%
1.5 OCLT
4pm
16.5
1Gal 8.3%
2pm
13.5
3Gal 8.3%
6pm
21.5
10pm
18.5
8pm
17.5
1Gal 8.3%
6/13/2017
6am
18
.5 OCLT
10pm
19
2Gal 8.3%
10am
16.5
1Gal 8.3%
.2 CC
6/6/2017
10am
15
1Gal 10%
2pm
15
1Gal 8.3%
12PM
16.5
1Gal 10%
6pm
18
2pm
20.5
10pm
16.5
4pm
18.5
6/14/2017
5am
16
.5 OCLT
6pm
17
2gal 10%
10am
13
.2 CC
10pm
22
2pm
11.5
6/7/2017
6am
19.5
6pm
10.5
10am
15.5
1Gal 10%
10pm
10
4pm
15.5
1Gal 10%
6/15/2017
6am
9.5
.5 OCLT
8pm
16.5
2gal 10%
11am
8
.2 CC
10pm
25
2pm
7.5
6/8/2017
6am
21
10pm
6.4
1Gal 8.3%
10am
18.5
6/16/2017
6am
9.5
0 CC
2pm
16.5
1Gal 10%
31 Gal Total
6pm
16
1Gal 10%
10pm
18.5
6/15/2017
6/9/2017
6am
20
TA
120
9am
18.5
CH
325
5pm
14
1Gal 10%
PH
7.2
9pm
17.5
1Gal 10%
CYA
50
Nice chart ;)
You did a decent job of keeping it above 16 most of the time. Just so you know, I regularly find that when people can keep the dose from ever falling below Slam (without nuking, eg normally just a few points above) it will shorten the duration, because as they say, every minute you're below slam level, the algae knows you're not slamming ;)
