Numbers look good.
The CYA chart says for a CYA of 40 , FC target is 5-7 with a minimum of 3. So as long as you don’t expect the FC to drop below 3 at some point before your next dose, you can wait. If you think you are using more than 2 ppm per day then raise the FC a little bit. Yesterday to today looks like a 2.5ppm drop assuming you didn’t add anything after you posted your numbers. It’s a little too early to get a good feel for daily usage but maybe bring FC back to 7 again and see what happens.
Just coming off the SLAM, I’d be a little hesitant to ride the minimum
