- Dec 28, 2022
- 48
- Plaster
- Pentair Intellichlor IC-60
Morning,
I'm looking installing a Stenner pump/tank to help me keep my Ph at or just below 8.0 and was wondering what you think? I'm averaging near 2 gallons a month of acid but I expect that to go higher once summer gets here and my high TA (340ppm) makeup water starts going in. I would have it inject a few ounces a day and with regular testing make adjustments as necessary. The goal is to handle acid a little less often.
Also, I think I understand that lowering TA is more effective when the Ph is at 7.0 or 7.2 but when the Ph is higher (8.0 or 8.1) and you add acid does that lower TA as well but just less effective?
As always, thanks for the help in understanding these things.
David
S1GE10T2B81S8 - 15 Gallon Chemical Tank With Econ T Pump - 8.5 GPD 25 PSI 1/4 Inch - Stenner
This Stenner S1GE10T2B81S8 is a 15 Gallon Gray Chemical Tank With Econ T Series Pump with 8.5 GPD 25 PSI 120 Volt 10 Foot Cord and 1/4 Inch Standard tubing. This combined chemical pump and tank system provides you a complete setup for your swimming pool..
www.poolweb.com
David
