Et all, I've finally given up on my HASA Liqidator. One of the cheap plastic float valves has broken as I was cleaning out the yearly salt buildup. Here's my question. I want to run a variable rate Stenner pump connected to my pump timer that I run approximately 10 hours a day. If I recall what I read on the forum some time ago was to use the Stenner 45MHP10. Does this make sense? Pool is 30,000 gal concrete. If this works I have two addition questions:
- 1/4 or 3/8 tubing?
- 7.5 or 15 gal tank? I buy Liquid Chlorine from the local pool supply in 5 gal jugs.
