Stenner Pump recommandation?
calsettle
18
Barto, PA
Et all, I've finally given up on my HASA Liqidator. One of the cheap plastic float valves has broken as I was cleaning out the yearly salt buildup. Here's my question. I want to run a variable rate Stenner pump connected to my pump timer that I run approximately 10 hours a day. If I recall what I read on the forum some time ago was to use the Stenner 45MHP10. Does this make sense? Pool is 30,000 gal concrete. If this works I have two addition questions:
  • 1/4 or 3/8 tubing?
  • 7.5 or 15 gal tank? I buy Liquid Chlorine from the local pool supply in 5 gal jugs.
crusemm
412
North Texas
I have a Stenner 45MPHP10 that i run for a set amount of time every night. I use a 15 gal tank and I think 1/4 inch tubing. I adjust tghe timer time when I need more FC
Reactions: calsettle
crusemm
412
North Texas
Not sure on your exact setup, but you could get the 110v version, and use a simple plug in timer that has set on off times. that's probably the simplest. I've heard of people having issues with the adjustable pumps, the non-adjustables are cheaper and pretty much flawless. You could go for a more complicated setup chaining your stenner into your pump timer, but that's a whole other mess to deal with. The one advantage is you can be sure that the stenner won't run without the pool pump running.
calsettle
18
Barto, PA
My setup is pretty simple. If you look at the photo. You see the tan timer box, 110v with the outlet to the left of it. I plan on plugging the pump directly to that outlet. Both the Stenner pump and the pump will be on the same timer circuit. I wanted to go with the adjustable pump so I could dial it in based on my pump duration. So, yes anytime the pump is running the Stenner will also be running.
crusemm
412
North Texas
you can adjust the rate of the pump by changing the tube size. mine does 10 gpd, roughly. You can get them from 3 to 40 gpd, figure what your chlorine needs are and adjust your pool pump timer accordingly. I suggest you get the high pressure version with the check valve. Also make sure you get the black UV resistant tubing if it's going to be exposed to sunlight.
calsettle
18
Barto, PA
yes, the adjustable flow lets you control from 0.5 to 10 gpd. I figure I can dial in the chlorine without changing my pump/filter duration.
Steve_in_C
386
Kinston, NC
I don't think you will like the adjustable pump. It makes a loud clicking noise. It would be better to have a nonadjustable one and just limit your run time with a timer. Get the largest tank you can. The 30 gallon will be better. It's a place to store bleach. You would also just use a barrel as your tank.
calsettle
18
Barto, PA
Steve, I went and bought the 15 gallon Stenner tank with the 45MPH10 Adjustable pump. I run my pump about 10 hours a day and I wanted to tie the pump into the sam e timer to keep things simple. I'm not worried about any noise this makes as my pool house is 150 feet away from my house. I'm still waiting on deliver, adding Liquid Chlorine manually until it arrives. I discontinued use of the LIqidator as one of the float valves broke and I was never able to get the Chlorine level in my Polo using it.
Steve_in_C
386
Kinston, NC
You can turn the adjustable pump all the way up to stop the clicking noise. Then you have a fixed dosing pump. Just adjust the run time with a timer.
yottabit
9
Plano, TX
Here's the install I did today at my house. I put lots of detail in the description. It might help you!
