I just placed an order for a Stenner pump fixed rate 100PSI 10GPD with 1/4 UV.
Going to use a digital light timer to control run time.
Planning to get a 15 gallon blue jug container to hold my chlorine, but had a a few questions.
1. Should I continue getting 12% liquid chlorine from pool store or just do 6% bleach? Wondering if time and heat will make the benefit of 12% mute.
2. Can i mix different percentages of chlorine in the tank?
3. I have seen a T pipe on some of the install posts that I like and was wondering what size the injection port needs to be in order to screw it straight in?
Any other recommendations for my new install?
thanks
-David
thanks
-David
