Hi all,
I recently ordered a Stenner EconT pump and reservoir that I'm installing to replace a Pentair Rainbow tab chlorinator. A pic of my setup is attached (with the tab chlor still connected). A couple questions on the plumbing and wiring plan:
1. Is there a way to connect the 1/4 inch Stenner line to the Pentair saddle clamp taps used with the chlorinator? I've capped the saddle clamps (pic) and will abandon them unless there's a way to utilize the old inflow clamp for the Stenner injection point. Otherwise, I plan to use the T where the cleaner pump currently connects to the pool return and buy a reducer bushing to fit the Stenner injector fitting. I no longer use the pressure side cleaner (bought a robot), so can remove pump and plug the line.
2. On the electrical side, I bought a 120v pump to have the option of running off a nearby GFI and the pump's built in timer, or maybe connecting to my EasyTouch8. If going to connect to the EasyTouch 8, any reason not to connect to the relay used by the cleaner? The cleaner pump is 240v, so can that be easily rewired for a 120v circuit by dropping the second load line, or is it more complicated than that? I guess same question if using one of the open aux relays too.
3. Last thing on the Stenner pumps/reservoirs, do those need to be removed in the winter to avoid freeze damage? I'm in Texas, so we're not talking sub-zero F, so seems like 12% bleach should be safe according to freeze temps for it on the internet. But, I don't want to learn the hard way if freeze protection is necessary.
Any thoughts or past experience making this switch much appreciated!
Thanks!
Thanks!
