Stenner pump for continuous pool chlorination
Apr 23, 2017
11
Plano, TX
Hayward Aqua Rite (T-15)
After researching non-stabilized chlorine tablets in an attempt to prevent my pool from getting nasty while away from home for several weeks, I stumbled upon a post on this forum talking about Stenner pumps. I was intrigued and started doing more research since the non-stabilized tablets dissolve in only a week, and are fairly expensive.
Today I finished installing a Stenner pump! It's working great and I'll dial in the feed rate rate over the next couple weeks.
If you want to see it in action, have a look at my short video. I also added a lot of details to the description, including which tap size you need to screw the included coupler directly into your PVC pipe.
Thank you to this forum. You've been helpful several times over the years. I hope this may give back a little bit to the community!
