Hi Folks,
I've decided to install a Stenner pump to dispense liquid chlorine. My pool uses about 32oz/day (in the spring). I've decided to buy the Econ T series pump, which combines a timer with the pump. The model I selected is 15 GPD, so I plan to run about 20-30 min/day, which will dispense about 1 oz per minute. The tank I purchased is a 15 Gal Stenner tank which is UV coated.
https://www.freshwatersystems.com/p...ontrolled-dosing-pump-15-gpd-tube-c-120v.aspx
I really need some help figuring out how to install the injection point into my pool plumbing. Should I drill a hole for the injector, or put a tee? If I install a tee, how that is typically done? Do I cut out a section of pipe, then just "slip in" the tee, then glue? Sounds like it would be difficult to slide in the tee and get it to fit. Can anyone shed some light on this?
