Hi folks,
I just installed a Stenner pump which I plan on using for acid. Everything is set, I just need to fill the tank and program the unit (Econ series).
My plan is to set the timer so that I can dose a fixed amount of MA each day when my pump is running high. My goal is to keep a stable range of pH of between 7.6 and 7.8. Are there any factors that I should consider as I plan out my dosing? I do use liquid chlorine to sanitize but am not sure exactly what impact that will have on my dosing regimen.
![12785.jpg 12785.jpg](https://www.troublefreepool.com/data/attachments/61/61402-9de8d76f7744af26e2b294c0d73c4121.jpg)
