The flow indicator is a good tool to see that the liquid is flowing, but depending on the pump you have, it can be hard to see the float move. For instance, if you have a 3gpd adjustable pump, and you run it at a low setting the float in the indicator isn't going to move very much with each pulse of the liquid.
