mguzzy
So lets review the salt levels for those that don't rememberhi, actually i am not fussed about salt taste, another knowledgeable member mention one time about staying at 3200 there is no taste there, and i have just repeated his comment, but to be honest who cares about taste not me, i just thought lower salt would be better for corrosion reasons, or i thought too much salt would cause dry skin, all that, but from all the responses here it seems a bit higher is no issue.....
so as said mine runs 3000 to 4000 so i will go in the middle at 3500 ....thanks again everybody
Your SWG pool-~3500ppm
Your tears-~7000ppm
Your Ocean-~35,0000ppm
There is likely not high enough salinity in a salt pool to cause any corrosion. The ocean is 10 times more saline, hence the higher level of corrosion. How sensitive an individual person is to the salt taste is a function of that persons pallet... For example I can't really tell the difference between expensive beer and cheap beer.. they both make me pee, So I drink the cheap stuff for a better ROI.
