CRAD_oz
Just put in your figures to Effects of adding.
5hrs runtime @100% (30g/hr)output is 4.1ppm.
That could work two ways, and I've seen this in my local big box store. They set out a pallet of chlorine (in boxes). I can see the date codes. They sell a bunch of it, but not all of it, then restock the pallet. But they don't rotate it, they just pile it on top. So now they've got new stuff on top, and old stuff on the bottom. That older stuff will sit there, buried, until they eventually stop restocking and sell enough to get to that row of boxes. Then people grab that, and it might be months, many months, old by then. That's just one way they handle chlorine incorrectly. But the employees aren't pool people so they have no idea chlorine gets old...hi, well i buy from Bunnings our huge local hardware outlet here they would sell tons to family's i would think turnover would be good
hi, ok i will look at pool math i was googling everywhere and didn't think to look at pool math....i will have a look at than now, i am now running it for 5 hours at 100%, thanksPS your model shows 35 g/hr which is 1.85 Lb/Day
OK, I saw a similar model but clearly not the right one that was 35 gr/hr. Same thing works just use the correct output for your model.hi, ok i will look at pool math i was googling everywhere and didn't think to look at pool math....i will have a look at than now, i am now running it for 5 hours at 100%, thanks
i just checked again on the Watermaid website if you look up Eco blend RP9 it shows a pic and says 30 grams per hour at 100%
Watermaid EcoBlend Salt Water Mineral Chlorinator 94500244
i have noticed just recently in one corner a light colour green patch about 1 foot long , i gave it a scrub and mostly gone hardly noticeable but its still there very faintly
just put in your figures to Effects of adding.
hi, i cant see anywhere to input all the info when i open , effects of adding, see pic, i did notice in my setup i have not put the data in the " 24 hour swg chlorine output" box, i looked up Watermaid but pool math does not have my model, but do have model EZ300, it puts out 1.58 pounds over 24 hours, i checked and thats exactly what my RP9 does, 30 gram per hour, 720 gram 24 hours, 1.58 pounds, so i selected that and its now saved in my pool math settings
but still cant see anywhere to input data into effects of adding....
ok will test tonight and early morningOCLT is the next step.
oh now i see it all, so simple , thanks im onto it.........Select SWG
ok all good i got math sorted now, so just to confirm, say my FC is 3ppm, i run swg for 5 hours @ 100% 30gram per hour to produce 4.1ppm, so at the end of 5 hours my FC should test to 7.1ppm ?
hi Dirk....ok i went back and remember the post now, but back then i was very overwhelmed, confused, all that and it didn't sink in, but i get it now, and with reading Chris's post its got the point home i am onto it now.....Waaaaay back in post #37
i didnt think of that, i wont hit target as its getting consumed from sun , ok so i understand now, its 8am i tested and its now FC 6, i have it set to add 4.1, i will test again tonight and see where its at, and keep testing every day till i get it to hold around FC6, seems simple now i understand it, thanksOnly if no FC is consumed
ok no more fractions.....nope no swimmers in pool so 6.5 down to 6 overnightLet go of the fractions
