- Apr 21, 2021
- 83
- Plaster
- Jandy Aquapure 1400
Should the baking soda be added all at once or over time?Adding the gallon of acid lowered your TA too much. 30 is not good.
You need to raise your TA to 60-70.
Add 6 pounds of Baking Soda to raise your TA. Each pound of baking soda will raise your TA by 5 ppm.
Watch your TA as you add acid and keep your TA at 60 or higher.
Don't add stabilizer until you get your TA up. CYA is a mild acid and will further lower your pH.
@mknauss
