PB finally added salt to the pool and started firing up the SWG about a week or so ago. I have also been adjusting my VSP and playing with the schedule since the PB had it on full speed for about 30 days.
I’ve noticed some bubbles. Sometimes a lot of bubbles. I know I have read that bubbles are normal with a SWG, but I’m getting enough bubbles to concern me. Started with noticing some bubbles coming up from the spa drain and one or two return jets in the pool.
I started running the pump at around 1650 rpm since that appears to be barely enough to get a trickle of water over the spillway. But I’ve started noticing after a few hours I’m not hearing the trickle of water anymore. So I ramped up the pump to 2750 and then I get a glut of bubbles coming out of the spa drain. I can then slow down to 1650 again and I get the trickle of water for a few hours before it gets clogged up with air/gas again.
Is this really normal?
Pool is about 13200 gallons. Jandy aquapure 1400 salt cell. Measured the salt level at 3400 with the TF Pro salt kit. The cell measured salt seems to be bouncing around between 3400 and 3800. Pool chem levels are still off a bit, PB is managing the chems at the moment, last visit supposed to be next week.
Do I have a problem?
I will attach a couple videos:
Pool Return Bubbles
Spa Drain Burping Bubbles
Pool Return Bubbles
