Hello,
I am in AZ and just finished draining my pool (just under 15K gal PebbleTec pool). Our calcium is pretty high here and I seem to have to drain about every 2 yrs. For context my Calcium Hardness was about 750 prior to the drain. I drained the pool on Wed, 4/29 and had it almost filled back up the same day. On the morning of Thurs, 4/30 I started off the chemical process by adding liquid chlorine and stabilizer (utilizing the sock method) and ran the pump all day. That same evening around 6p I tested the chemicals with the following results:
Chlorine = 6.5
pH = 7.4
Total Alkalinity = 190 (high)
Calcium Hardness = 300
CYA = 0 (hadn't finished adding the stabilizer yet)
CSI = ~0.21
I let the pump run overnight to finish dissolving the stabilizer. Ran another test this morning at about 6:45a and got the following results:
Chlorine = 4
pH = 7.6
Total Alkalinity = 200
CYA = 40
Temp = 76
CSI = 0.42
The chlorine seems to have increased too much for it being a 12-hr period, and the TA and pH are up as well. TA is way too high; according to recommended levels it should be 60-80. IF it was at 70 I'd have a CSI of -0.08, and I'd assume the pH and chlorine levels would be more stable. High TA is my issue and I need to start bringing that down ASAP? Thanks in advance for the help. Love this site.
Chlorine = 6.5
pH = 7.4
CSI = ~0.21
Chlorine = 4
pH = 7.6
CYA = 40
Temp = 76
CSI = 0.42
