- Jun 27, 2022
- 20
- Fiberglass
- Hayward Aqua Rite (T-9)
I don't know if I'm dealing with algae or dirt or....? We live in the country, acres of dry weeds and dirt around us, 50yds from a 10ac dirt lot with cows and goats. The wind blows around here. Three weeks ago the sand filter housing began leaking at a seam. It took 6 days to get it replaced - during that time, pool was on re-circulate and chlorine maintained at 9ppm with CYA of 70. The sand from old filter was deep cleaned and installed in new filter housing + 1 bag of new pool sand. Filter was run for 24/7 for 7-10 days. Pool has been cloudy since a little before the original sand filter went bad. Backwashing/rinsing not helping. Added 1/2C DE to sand filter- no change. The white stuff in the pool robot filter is zeofiber I was dumb enough to try (before the original sand filter went bad) as I haven't gotten the pool crystal clear all season. The zeo fiber in the robot filter is present daily (this, after deep cleaning sand and installing the new sand filter0. My question is; do I have algae, dirt and or a zeo fiber regurg issue? Maybe all of the above, the Tri-fecta? I think I need to start the SLAM process and see if it improves? I haven't done the OCLT test yet. Will start that tonight. Here are my test results from this morning;
FC-10ppm
CC- 0
PH- 7.6
TA - 125
CH - 125
CYA - 50
What do you think and am I thinking this through correctly? My pool is my nemesis this year. I just want to be friends again.
* Could not figure out how to attach a video
FC-10ppm
CC- 0
PH- 7.6
TA - 125
CH - 125
CYA - 50
