Test Results: I used to use a copper ion system but have since disconnected it... Please Know that I had yet to add any chemicals to the tap water when tested and still filling the pool as I type... It's pouring rain outside and will continue for the next week which will continue to raise the PH.
Test results prior to chemicals added: FC .07, Total Chlorine 1.75, PH 7.9, TA 85, CH 128, CYA 5, Phosphates 1134, TDS 600 Test results completed from a local branch of large corp company here in dville...
I have since added 1/2 gallon of muriatic acid and 3 scoops of Leslie Power powder plus which is approximately 72 ounces... I believe I'll need another 80 ounces at some point but (again the pool is only about half full at this point 15k gallons and still filling and should be full sometime this evening)
I have not added conditioner to the water yet as the clerk sated it was only going to get diluted due to rain... I argued with the guy thinking I'm going to need at least 8 pounds of conditioner regardless and I'd like my shock to bond to the conditioner to hold longer... Clerk seemed to think i need to wait until next week to add conditioner as we are expecting a weeks worth of rainy days... I simply don't agree and can see my pockets getting lighter from all the wasted money in shock that I'll be using for the next week without any CYA in the pool.
Any thoughts as to what I should be doing in addition to what I've added so far?
thanks in advance
thanks in advance
