The issue I am concerned with is the 30+ degree slope into the skimmer opening. They used Mortar to build up the pool shell to match the bottom of the waterline tile. I am adding new photo to better show the issue. Wider shot to show more perspective.If I understand you correctly, yes the skimmer will work 1” above the normal level. Where you run into problems is when the water level is too low and a chance of sucking air into the plumbing.
That certainly isn't the proper way to do it.The issue I am concerned with is the 30+ degree slope into the skimmer opening. They used Mortar to build up the pool shell to match the bottom of the waterline tile. I am adding new photo to better show the issue. Wider shot to show more perspective.
The tile installers said they used their laser to set tile based on highest bond beam elevation. There is an area along left side that is slightly higher and I think BB at skimmer is slightly lower. Tile is 3/4" above BB next to skimmer.Preface my comment that I’m no expert but it seems like the tile to the right of the opening is a fair amount higher than the bond beam. Is the bond beam level all the way around? In other words is the tile the same height above the bond beam everywhere? If so, could the tile be lowered? Might not get you all the way there, but would help some.
Here are some pictures more pictures. They also raised the tile on the SPA, I guess to keep elevation same relative to pool. The one pic is highest point of BBThat certainly isn't the proper way to do it.
The pool water level should be about 1/2 the way up the height of the skimmer throat and the entryway should be level with the bottom of the skimmer entry, not sloped downward from the pool to the skimmer itself.
Post a few pics of that area from further away so we get a better idea of the surrounding area.
They said they set tile based on hightest point on the BB. The spot that is the highest the tile is 3/16" above BB, it is the middle picture. At skimmer tile is 7/8" above BB.In the last pic showing tile to either side of the skimmer opening - it appears the tile runing left/right of the skimmer are higher than the top of the bond beam. Is that correct or just the pic angle?
Time to have a serious discussion with the tile guys.
I agree, the workmanship is horrible. I have found some other signs that point to the lack of planning the layout. They are supposed to redo the waterline tile since I caught them using Versabond thinset instead of one rated for water submersion. I will be more observant this time.Sorry to say, but that is some cruddy tile work.
All the grout lines need to match up.
For the side pieces into the skimmer, the joint between the tiles should have been about half way along the distance instead of having the very small tile piece against the skimmer mouth.
And the bottom edge of the lowest tile needs to be at the base height (or close to it) of the skimmer throat lower part. Then they fill in with small pieces of tile at the top of the bond beam.
Which tile contractor did you use? Want to make sure I steer clear. I’m also in the west valley.I agree, the workmanship is horrible. I have found some other signs that point to the lack of planning the layout. They are supposed to redo the waterline tile since I caught them using Versabond thinset instead of one rated for water submersion. I will be more observant this time.
