This feels like Groundhog Day (the movie).
Every year, I say I am going to close my pool properly - I don't, and it turns green.
Ridiculously, I have been changing my pool liner EVERY YEAR in my above-ground pool, usually because it has fallen in.
This year, I left my pool "more full" and also installed a "liner lock" - my liner is still up!
BUT, the pool is VERY green. I have already drained it down to around 1/3 full (hopefully not a mistake). Last year, I went down to only a few inches left, and my liner fell in. This year, by leaving it fuller, and having the liner lock, it is all good for now.
My questions are:
1) Should I start applying chemical with the pool only 1/3 full? It is currently filling now, with a garden hose. It takes 1-2 days to fill with the hose. Should I wait until it's full and I can run the pump? Put in bleach now? Or shock? Or algecide?
2) After the pool is more full, i planned to do a lot of "vacuuming to waste." IF I have chemical in, this will dump a lot of the chemical anyway...thoughts on this? Wait until done filling/vacuuming to apply chemical? I worry though, the longer I wait to apply chemical...it's likely to just stay green I think...
3) Speaking of vacuuming, I do have some flocculent...should I do that now? Or wait until the pool fills so I can run the pump?
My pool is 48" deep x 20 feet across, if I remember correctly (it's either 18 or 20 ft).
At this time, all I have access to is around 5 gallons of bleach, some of those disinfectant "pucks" that you put in the floaters, a little powered "shock" (HTH smart shock) and a fair bit of algaecide....oh and some flocculent. I can run to the store today to see what else I can pick up.
I suspect the answer is going to be to get bleach in this thing ASAP, and maybe also start with the brushing, but I"ll defer to the experts.
I'm a bit worried I won't be able to get bleach during this COVID scenario, so I may have to buy shock or at least bleach from the pool section rather than the grocery/cleaning section.
Anyone else needing to adjust due to lack of bleach availability?
Maybe next year I'll close down properly, but at this point I'm leaning towards just letting it go every year and figuring out a good start-up procedure.
Our "down" time here in Iowa is around 9 months where the pool just sits. I get typically around 3 months where the pool can be open. I will gladly research more if there is an easy, cost-effective way to winterize for 9 months...but so far I've just let it go and tried to sort it out the next season. It's just a long time to sit unusued, and a short swimming season.
I'm open to any and all tips though!
My questions are:
