Start up Guide
DoDo1975
61
Kelowna, Canada
Is there any good pool startup guide anywhere. I have spent the last 4 months building my pool and I have everything hooked up, but need to build up the guts to start it all up
I have a cartridge filter, heater and SWG as well. I suspect all i need to do it prime the pump and turn it on, dump some salt in and then take a sample down to the pool store for chemicals.
Is it this simple?
Not much of a startup guide needed for a vinyl pool.
What is the pH, TA, CH of your fill water?
Add water and ...
You asking about water chemistry or equipment operation?
Fill the pool with water up to at least 1/2 way up the skimmer mouth; set all valves properly; turn on power to equipment; put ET panel in SERVICE mode; turn on pump; pump should prime and water start flowing; check for leaks; check water level in skimmer.
Post pics of your equipment if you want to discuss in more detail.
