I just opened my pool and it's nearly black it's so dark green. Should I drain or try and clear up. I prefer to try and clear up as it's not cheap refilling the pool. If I try any tips on the best way?
Mike
Mike
I have never experienced such bad water. I've always started new water each year. I've nearly always maintained crystal clear water. So I'm wanting some advise that's all. I thought these forums were here to help. I know I need to slam the pool. I've done that. I was just asking for more help/advise. Everyone can technically ready the pool school and never need to go on this right? if you never had such a problem with near black water then lucky you, but please have some compassion on someone that has never had and want some help. If I'm not aloud to ask for help on this forum please advise and I'll leave quietly.
Thank you!I've beaten black and dark greens across the country for myself, friends, and family. I understand what you're looking at doesn't seem to compare to the "green swamps" that you're reading about.
To answer your question directly, a complete drain is almost never the answer; however, depending on your answers to the next questions, a strategic siphon vac partial drain from the bottom 1-3 inches may be the game changer you're looking for. This pumps out the grossest, most settled, heaviest sediment, dense decomposing leaf layer that is reflecting that black and would require a lot of FC to oxidize to crystal clear.
Let's see what you're dealing with:
1) Are you or another responsible adult available for a few hours to perform a modified version of carefully vacuuming the pool? If no, just ignore my post and follow exact defeating algae and slam procedures.
2) Do you have some open grass a few feet away from the pool that could stand to be lightly flooded without the water pooling against the pool wall, going into your home, a shed, or anything that doesn't like water? - if yes, yay! continue, if not, ignore post
3) Is there the possibility that there sticks/branches/other liner pokers in the pool or was it covered? How about leaves and pollen? - this matters no matter what you do
3) Do you have the ability to take a plastic (not glass) pitcher or bucket and remove a sample of the water? Try to reach away from the wall and try to avoid surface layer of water. If you do this and then pour it into a glass cup or jar, how does the stream of water look? How does the glass look once filled? Ignore floating sediment. Does it let light through? Would you call it clear-ish water-like? Is it like green tea? Or is it actually motor oil black sludge? - if the substance in your pool under the top inche and above the bottom three inches is basically water, we're talking about 93%+ of your pool being easy to treat, but the extremes at top and bottom being tough and costly. A siphon vac uses a pool vac head and hose to siphon/pump out, without the motor, just gravity, the bottom muck and garbage that is the real trouble in your tar pit, leaving only the surface for you to skim, then you have a normal SLAM ahead of you. YAY!
4) Do you have a Taylor K-2006 or TF-50 or TF-100 test kit? you really need one of these. It's an investment of less than $100 that will save you way over $100 each year.
5) Do you have a vehicle that could carry, let's say, 20x one gallon jugs from Wal-Mart at a time? I called the Leslie's in your city and they don't sell liquid chlorine, so you're probably going to find Wal-Mart the cheapest way to get your pool beautiful and safe, drain or not. We can help you make a pretty complete shopping list before you go to keep your trips down and save you money.
6) I see you have a pretty big pool, maybe 35-40k, could I convince you to either complete your signature or tell us about your pump/motor? A picture would even help.
It costed me $200 last spring, but I am also worried that the water will drain under the pool and cause even more trouble. It was leveled last spring and they had to dig down a lot by where the drain is. And the drain Is too close to the ground to get a hose screwed onPiper Mike, how expensive is it to refill your pool?
I'm asking because we started out with almost black water and bullfrogs last year. We had an undersized filter so it took between 20-30 days. At that point we had spent hundreds of dollars, and frankly since we are on a well, it would have been better to start over. I hear you. It is totally discouraging. If you have an idea of what it would cost to refresh your water, it may be so inexpensive it isn't worth the time, effort, and money it will cost to SLAM. That is my two cents.
Thanks againGood replies. I'm looking for a couple pictures from a few years back that might help you.
In the mean time, is the pump running?
Check the expiration dates on ph test chemicals. Did you test pH before adding shock?
Please don't add more shock yet, as pool school teaches, you are not getting much for your money with chlorine if the pH isn't in range. pH test isn't valid if FC is 10+. Luckily for you, your swamp and the sun should eat up those jugs you put in before sunset I'd guess
Always ensure pH is in range before chlorine additions to be as thrifty as possible![]()
Thanks I've read that tons of times. Please read my question. This water is nearly black
I'm wondering the BEST way to clear up the water when's it's so bad. I poured 4 gallons of pool chlorine in there and filling the pool up currently as it's below the hose holes. thanks
