Starite AFS Replaced and Won’t Ignite
dielseman
308
GA
Hey, I replaced the AFS module on my starite sr4000 and it still won’t ignite. Starite says the next thing to do would be to replace the controls module. Has anyone replaced both of these items and gotten their heater to ignite? Wondering if I should’ve just replaced the module.
Describe the startup sequence and error you are getting.
What AFS components did you replace?
So to follow up on this there are lights turning on the interior control panel when I turn on the heater. The fenwall does blink 3 times. I have tried shutting the gas on/off and turning off all the breakers for several minutes. Nothing worked. What is the next step? Should I clean the filters?
