- Jun 5, 2020
- 152
- Plaster
- CircuPool RJ-60 Plus
I'm going to be installing a SWG in the next month or so, and have considered adding an acid pump at the same time. I've decided to wait and see my acid demand after the SWG is running. Is there a standard plumbing fitting I could include when I do the SWG install to prepare for a possible acid pump addition? Should I install a check valve between the heater and acid pump connection to protect against accidental low pH, or is it sufficient to rely on the timer removing power to the acid pump while the filter pump is off? Thanks!
