Why not a bolt on handrail for the spa? You can use any stairs you want to.
The handrail I got can be rotated 180 degrees to assist getting in and out of the tub easily
I honestly don't know the brand. The installers unboxed it at their pickup truck and brought it in and installed it. It's similar to the Vevor Handrail in it's mounting brackets. But is has two quick release buttons that allow you to turn or remove the rail the quick release buttons allow you to rotate the hand rail 180 degrees and lock in position. When the cover is open, the rail will rotate and lock, we normally rotate it with the cover on the make sure the 4 y/o grand daughter doesn't play with the cover. While the cover does have locks, the visual deterrence keeps her from playing with the locks.
