- Mar 25, 2019
- 692
- Plaster
- CircuPool RJ-30 Plus
I am nearly two weeks out from a replaster and I have a few spots brushing wouldn't remove today. I am pretty sure they are from a nearby tree dropping things, but the rest of the stuff vacuumed or bushed away. The one that is within arms reach, I lightly scrubbed with a stainless bristle brush and it seemed to fade a bit but not go away. I did not want to get carried away with a harsh brush on new plaster . I was also thinking using a chlorine puck, but again not sure with 11 day old plaster. Should I let the plaster cure more before I mess with it or try to remove it now?
Also have a plain white spot near my main drains. Not sure what it is as I haven't got in yet and brushing doesn't do anything. Not sure if it it raised or not but it didn't seem to catch on the back of my brush. This spot I am truly puzzled about. I really don't remember seeing this last brushing either.
The pics are for reference.. I know it super hard to see a photo thru water, but the stains are brown-ish green. I am on city water and it is hard, but never had an issue with copper or iron. The water is pretty balanced, not sure if you can see my poolmath logs. Had to add some acid to get the PH down from 8.2 just now.
