I'm about to drain and refill my PebbleTec pool after 3 years in the AZ sun. While I am at it I'd like to try and remove some white staining which I think I created when I drained the pool last time by using a chlorine rinse to remove algae (see pictures). You can see the staining around the main drain where I think the chlorine solution accumulated and sat for a while causing some kind of stain. Any suggestions on what will safely remove these?
Also the PebbleTec overall has kind of a dull look to and I can see a scale buildup on underwater lights. I also have a waterfall that has a substantial scale build-up on the tile as well so any suggestions/product recommendations on how to clean all these areas would be greatly appreciated!
