Brand new pool, only eight weeks since it's been filled and since day 1, this stain has been getting worse and is around the entire pool (see photo). Nothing added to the water (tap water to fill), just a little muriatic acid twice. Pool builder doesn't know what caused it.
The pool builder says they need to add acid to the water and over a four day period, brush the pool twice a day. The heater can by bypassed, but I'm guessing since this is a four day process, a lot of acid will be added.
Will this affect the plaster at all, as in make it thinner or damage it? Can any of the valves or pumps be damaged? I'm concerned that this will work but the pool could be damaged long term, and so I'll need a longer warranty from them?
Thanks for any input.
- - - Update
- - - Update
