- May 3, 2014
- 62,674
- Fiberglass
- Pentair Intellichlor IC-40
That is great. The TF100 with Speedstir is the better value, but the K2006C will work fine.Disregard...ordered K-2006C
OTO?I suggest you stop making any adjustments based on your 5 way kit but to keep enough chlorine in the pool for the yellow tinge to be in the OTO test. The pH may be able to be believed if the TC you are reading with the OTO is low enough.
Thanks. I thought the purpose of the SWCG was to eliminate the need for chlorine? We are in Houston and weather for the next week is 50-65F. How do you know how much to flow thru pucks. Leave it on all the time? Why not just add stabilizer to get CYA to 40ppm for winter?You will not be testing BR as that is Bromine and none have or will be added.
You will need liquid chlorine for the winter. Or only raise your CYA to 30 ppm and use the pucks for the winter. Be sure they are dissolving enough to get your FC in target range. Test pH often as the pucks are very acidic. Test CYA monthly to track it. Stop using pucks if it gets to 60 ppm (not likely over winter).
No need for any salt. Will be too cold for the SWCG anyway.
I get muriatic acid at Home Depot. 2 gallon box of 31.45%
Should never need sodium bicarb aka baking soda.
Thanks. I prefer to not use the chlorinator as long as the SWCG can keep the chlorine level at the necessary level after adding stabilizer - woudl rather be adjusting one thing rather than two. The SWCG (IC40) is currently set at 50% output. So I understand, if I add stabilizer and get the CYA to 40ppm, I can then just bump up the SWCG output if the chlorine level starts to drop, correct?The SWCG will generate chlorine when the water is warm enough. You will be using less chlorine during the winter.
You will have to adjust on the chlorinator if you wish to use it. You had the pucks so I described how you can use some of them this winter. Up to you. The lower CYA if you use pucks is because the trichlor pucks will add CYA as they add chlorine to the water.
