For the past 4 years, ever since having a pool , new at the time, I add stabilizer ea. year when first opening, going to 40 ppm from mostly 30ppm, loss of around from 10ppm due to water level reduction when closing and water addition from rain/snow through winter and early spring.
After adding the correct amount of stabilizer by volume, I try to increase 10ppm or so to get to 40-50ppm.
I don't use pucks, just liquid chlorine , 12% from Menards.
After the first hr of it in a sock in front of return, I squeeze and get plenty of white foam.My pump runs from 3pm -10pm.
After that it seems to not dissolve at all with no effect when squeezing the sock.
After a certain time does it just not do anything once it gets to a certain point? Over 2 days at 4 hr ea. I think half is dissolved , I don't leave it out after I head in for the night as I don't want it just hanging there when the pump is off, if that matters even.
