I just renovated my system, upgraded pool pump from 1.65 VSP to 2.7 VSP, new plumbing, valves etc. Probably looking at things closer on start up to make sure nothing is leaking when I noticed the filter, the one thing I did not work on is leaking. Guessing new pump is really pushing the pressure although I am not sure the gauge is reading any higher than it used to (20). The O-ring feels like a dish rag. How often should the O-ring typically be replaced? I cleaned the filter which was pretty dirty from opening, put it all back together, boned on the closures & it still leaks a touch.
