We don't get much freezing weather here in North Texas so we leave out pools filled year around. A freeze switch kicks the pump if temps hit freezing and generally, moving water is more than adequate to protect our equipment. Last week or two, we hit freezing several days - no biggie, I assumed my pool would just protect itself. Turns out, not so much. The motor starter capacitor had gone out, so when the freeze switch tried to start the pump with a blown capacitor - no go and I was not paying attention. Temps warmed up, I went to check the pool equipment and find that the pipe between the filter and heater (about 5 feet long) is split open longways. Still don't know if any other pipes have problems because when I got it replaced, I turn on the pump (which has a new capacitor now) and water spews from the manifold (bottom bolt area) of my Sta-Rite heater. So far, a capacitor I could have bought online for $8 (I paid the $20 convenience fee to get it from a local pool store) has created a lot more problems than that thing is worth.
First, freezing temps (in the high 20's) for 4 or 5 days straight, the pump was obviously not on this entire time - what is the best way to check how much damage the freeze did to my equipment? We replaced the heater about 8 years ago, used it maybe 3 times. We can extend season if we use it, my wife complains about the waste of gas and associated cost plus Mr. Murphy can't resist, all three times we heated the pool, summer took a detour and we ended up heating for 3 weeks. So, I am inclined to create or plumb a bypass, but if there is a freeze plug in that area I would much rather keep my options open. Any advice/suggestions?
On a collateral note: Is there any warning sign "average life" on starter capacitors I should pay attention to in the future. 13 years with a pool, this is the first time we have had a pipe freeze, but then the pump motor and freeze switch were also replaced about 8 years ago when the heater was done so maybe I was just due.
Last but certainly not least - any simple method of checking underground lines?
