@JamesW
Ugh! The new T15 cell (model TCell15SWP, suppose to be compatible with Aqua Rite controller) arrived today and I installed it, changed the controller setting to T15, and fired it up. For some reason with the new cell I‘m still getting a low instant salt reading! In fact, it’s the same instant salt reading the old cell (from 2015) gives on the T15 setting!
Now I‘m wondering if the problem all along wasn’t the cell, but something else.
Here’s the diagnostic readings for the new cell, controller set to T15
2200 (I reset the Avg salt setting to match the instant setting)
26.2v
5.06a
80P
-2200
AL-0
r1.50
t-15
I turned it off and back on to switch polarities, the only difference was 25.7v, 4.96a. Everything else was the same.
Of course, shortly after it powers up, the Low Salt and Check Cell lights come on (steady) and it stops generating (Generating light shuts off).
Any idea what may be going on here? Anything I can check?
Thank you.
PS - I just check salt level with the Taylor drop test; 3000ppm (tested twice to confirm)
Edit: I also made sure the salt cell plug contacts were clean. They looked brand new on the controller, but I cleaned them anyway. That made no difference. Also, if it matters, the controller was installed March 2004 and the main board was replaced in spring 2009.
