Check the salinity two new different reliable ways.
Get a different drop test kit and a calibrated meter.
Any suggestions? I have no idea what else to get.Check the salinity two new different reliable ways.
I don't think it is the board since the the voltage displayed and current appears to be within reasonable ranges although current is tad bit low which is reflective of the low salt value. Normally when the board fails, the voltage is zero or very low. Where did you buy the cell?Any suggestions? I have no idea what else to get.
Is it possible something on the main board is wearing out, giving inaccurate readings, though not outright failure?
Thank you.![]()
Interesting. I hadn’t noticed anything odd about my K1766 results since I bought it last August. Perhaps it‘s been off from day one. I’ll order new reagents and see what I get.Based on the amperage, I think that the box is correct and your K-1766 is incorrect.
What is the water temperature?
You can check the amperage going to the cell if you want to and if you have a clamp ammeter.
Get a different K-1766 test kit and a meter with a calibration solution or go to a pool store.
Hayward Digital Handheld Salt Meter - Model GLX-SALTMETER - INYOPools.com
Hayward Salt Meter, Hand Held Digitalwww.inyopools.com
Ultrapen™ PT1 | Myron L® Company
The Ultrapen™ PT1 is an accurate and reliable pocket water tester for measuring Conductivity, TDS, Salinity and Temperature.www.myronl.com
PoolMeter™ | Myron L® Company
The Myron L® PoolMeter™ is designed specifically for the Pool and SPA Industry with “DUAL” Ranges, accurate and reliable results and is simple to use.www.myronl.com
Thanks for the post.I don't think it is the board since the the voltage displayed and current appears to be within reasonable ranges although current is tad bit low which is reflective of the low salt value. Normally when the board fails, the voltage is zero or very low. Where did you buy the cell?
Do you have any salt? Add a handful to the skimmer and see if you can get the unit to operate within range. A small amount of salt dissolving slowly should raise the effective salt level just enough to get the unit to work. If it is working ok, then you might just want to increase the salt in the pool until the unit no longer alarms. It doesn't really matter if the salt display matches the accurate tests or not. What really matters is if the unit is generating chlorine. I think there have been others on the forum where the measured salt levels are much higher than the SWG displayed levels (500 ppm+). Something in the water may just be retarding the electrolytic reaction.
Sorry I missed you asked that before… 80 FWhat was the water temperature for these readings?
2200
26.2v
5.06a
80P
-2200
AL-0
r1.50
t-15
Thank you for checking that.I checked a different system and got these results.
Temp: 80
Volts: 24.5
Amps: 5.26
Salinity: 2,700
Based on this, I think that the salinity reading from your system is likely to be correct.
The K-1766 is a good test kit, however, I never rely on a single test, especially when I get different results from two different methods.
I always like to have at least two tests in agreement.
If two different tests are out of agreement, I get two new tests to see what's the real salinity.
So I searched “calibration solution” and came up with a zillion options with no clue on what’s appropriate for the meters you linked. The description of the meters were of no help.If you get a cheaper meter, get the calibration solution to verify that the meter is accurate.
Thank you.Amazon.com: LaMotte Calibration Fluid Pool Water Salt Test Meter,6005-J : Patio, Lawn & Garden
Buy LaMotte Calibration Fluid Pool Water Salt Test Meter,6005-J: Water Test Kits - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Yes, I bought an OEM cell. I registered it with Hayward and they sent an email confirming my registration and warranty (3 years, plus 90 extra days for registering). I’ve have good luck with prior OEM cells, so I stuck with what I know. From reading, it seems generic/aftermarket cells don’t last as long, but of course they are cheaper as well.Did you get the OEM T-15 cell? And what is your warranty look like?
Update on post# 50: According to my outdated (2016) K-1766, my current salt level is at 3200ppm and I am not doubting that. We have a 20k gals pool and each year, I have to add a 40lb bag of salt or two. Last week, I replaced our 4 year old OEM T-15 with a brand new Jacuzzi J-SC40H off eBay for half the price of the OEM T-15. I really don't care about the warranty scheme, for me it's just baloney. But hey, I think I lucked out. I am very happy knowing the replacement cell reads higher salinity than my outdated K-1766. For me, that indicates the cell is beyond good. But of course, time will tell.
For reference, here are the diagnostics post installation on 5/26/2021:
2800
72
25.2
6.78
100P
-4000
AL-0
r1.59
t-15
Reverse Polarity:
2800
72
25.2
6.78
100P
-4000
AL-0
r1.59
t-15
Follow up (6/6/2021)
4200
70
25.4
7.12
100P
-4300
AL-0
r1.59
t-15
Reverse Polarity:
4200
70
25.2
7.22
-4500
AL-0
r1.59
t-15
At this point my experience with the K1766 has not been good. We’ll see what happens when the new reagents arrive.Granted the salinity is within the recommended range, a known good T-15 cell should pull 6.+ Amps. In comparison, our swcg when first installed matched the K-1766 salinity test results at 3200ppm. And I'd say my trust for K-1766 was built on that! Do you have access to somebody else's Aquarite controller to perform a swap test?
I for one have no love for the generic chinese knock off salt cells regardless how cheap they are! I did my homework and learned from others in here that the Jacuzzi is a well reputable brand and was sold by Leslies. Circupool 40k cell is also getting good reviews here and I'll be more than willing to give it a try the next time around if I can justify the cost.
