Spots on pool
Looks like the plaster is being eroded.
Do you add solid chlorine, especially dichlor or granular trichlor to that area?
Any chance of seeing some pictures or some more detail?
Just uploaded them sorry
no we use chlorinator . Tabs are never in pool
what would cause that?
OK -- can you post a full set of water chemistry test results using your own test kit?
Those are from what type of testing kit.
Are the eroded spots only in shallow areas that may be dry when the pool is winterized?
You need a proper test kit. I suggest the TF-100/Pro or Taylor K2006C. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
Once you get your test kit, run a full set of tests and post them here.
Plaster erosion is normally due to low CH, low TA, low pH, and / or the use of granulated acidic products in the area of erosion.
Thank you for your help
