We have a 13,000 gallon plaster in-ground pool/spa combo that was built in 2010. We've been in the house for a year and - thanks to everything I've learned from the forum - I've been meticulously maintaining the pool and water chemistry.
The pH tends to run high because of the spa spillway and also a large waterfall. To balance the pH and keep it below 7.8, I need to add muriatic acid quite frequently - almost every other day in summer when the waterfall is on. In the summer, I also need to add about 20 oz of liquid chlorine per day to maintain the chlorine level close to 4-5 ppm. If the alkalinity runs below 85 ppm, I add baking soda. CYA is 40 ppm and CH is around 320 ppm.
Despite meticulously maintaining the water chemistry, I just noticed what appears to be some new spot etching on the plaster in the deeper end of the pool where I add the chemicals. I'm trying to figure out what could have caused that and how to prevent it. When adding muriatic acid, I fill up a 5 gallon bucket about half full and then dilute the acid in the bucket before adding it to the pool (never more than 25 oz at a time). I don't dilute the liquid chlorine or baking soda before adding it. Pump is always on high when I add chemicals.
Do you think the spot etching could be from when I pour the muriatic acid into the pool? Not sure what I could be doing wrong. The overall pH never tests below 7.5.
The pool has never been replastered and we're trying to put that off as long as we can due to costs. Not sure if there's anything that could help prevent the etching and also remove the stains? I've seen the Jack's Magic Stain Solution #1 but am not sure if TFP recommends that product. Would a chlorine wash or acid wash help?
Picture of some of the etching is attached. There are some additional green stains, which are probably copper and have been there for a while. Not as concerned about those for now.
Thanks for any advice you have!
13,000 gallons
Pool/spa combo
FC and TC 3.5
pH 7.6
TA 100
CH 320
CYA 40
Pentair quad cartridge filter
Pentair Intelliflo Variable Speed Pump installed last year
Pentair MasterTemp 400 BTU heater
13,000 gallons
Pool/spa combo
FC and TC 3.5
pH 7.6
TA 100
CH 320
CYA 40
