- Aug 10, 2021
- 5
- Plaster
- Pentair Intellichlor IC-40
As a follow on to these two previous fantastic threads
Replacing Pentair CCP drain port with a valve and hose attachment from JMastron and Pentair CCP Filter - replace drain plug with valve...
I don't have a spigot at my equipment at all, and I don't have a house one nearby either. I would like one to drain water at rain and also to use for quick spray off anything. My pool is connected to my irrigation system, so water would ultimately be coming from same place.
I was asking PB to come back and add one at top of pump line on way to filter as it is most convenient to reach, and he's suggested what's been done on the previous threads. I'd see the advantage of the hose at the filter for many of the reasons described above - #1 being the mess created when I drain the filter to clean the cartridges. (Picture attached).
Questions:
If the connection is at filter, should/do you have to run the pump when using the hose?
Could you run PVC further from the filter so that the ball valve is at a more convenient location to access?
Is there any additional value to the spigot at the pump rather than the filter?
Thank you
Questions:
Thank you
