Photo of the leak. It takes it nearly 15 minutes to develop a single drop, as seen here.
Possibly, or just a fluke. I think you'll be fine either way though.Correct thinking, or am I off?
I only glued it down at the five outer points. I saw that technique used in several videos. That should be good enough right???
I just replaced my gasket, and I am having the exact same issue with the loose handle. The spring and everything underneath look to be working just fine. Did this eventually go back to normal for you?Ok, I've torqued everything evenly down and I may have a problem??? The handle is "loose." I can freely select different positions, but the rest state is loose. See attached photos. First one is where it rests, second is where I would expect it to rest. (I'm holding it up)![]()
