Hello all. Just finished a winter install. It's been a really windy week so the pool has gotten some extra debris and I'm using the very basic vacuum that was included with the pool install(still researching a permanent solution). It connects to the top of the skimmer and is very basic suction but it's a small pool so honestly I think it should be fine. I have a Pentair VS pump and my issue is even when I follow the instructions to prime the pump and make sure the line is full of water it seems the pool pump is struggling to pass through enough water and the water level of the pump dips greatly. I've played with a few speeds and I haven't found one that seems to work well consistently. Is there a good rule of thumb as far as speed or any other settings needed to properly vacuum without damaging the pump?
Thanks all!
Thanks all!
